Header from paper DWG duplicate
  • Dec 7, 2018 12:07 PM UTC
  • 5 replies
  • 73 views
mr_fme
Forum|alt.badge.img+9
I'm doing a DWG to DWG conversion, but only the top-of-the-sheet header is doubling. I've already used duplicatefilter, but I can not resolve it. This only happens at the top of the sheet ... could anyone help me?
Look below:
Thank´s
gio
Forum|alt.badge.img+15
  • Dec 7, 2018 12:53 PM UTC
@mr_fme
Hard to tell what is causing this without relevant data sample and your workspace.
It seems your are sending a object twice to the writer. Maybe labeling an insertion point that is already represented by an AutoCAD text object.
mr_fme
  • Dec 7, 2018 3:03 PM UTC
@mr_fme
Hi @gio.
I have already checked the only transformer matcher in my workspace and it has nothing related ... From what I see the problem is even at the time of writing and building the DWG by the FME.
Attachments follows template file
safe_test.fmwt
Thank you for your help
gio
  • Dec 7, 2018 4:10 PM UTC
@mr_fme
Hi I checked the dwg after running the script.
One the headers is a block reference. As you write this same object as a MTEXT, you see a seeming duplicate.
This is not visible in fme datainspector (afaics).
mr_fme
  • Dec 7, 2018 4:17 PM UTC
@mr_fme
@gio,
Correct! In FME Inspector is not visible. But in AutoCAD, it´s possíble see the duplicates title clarealy.
@mr_fme
Just uncheck the option MTEXT in the input data to not see duplicate the title
