Handling multiple geometry columns
  • May 21, 2019 1:01 PM UTC
  • 140 views
I would like to use the FeatureReader to read the data from the PostgreSQL (PostGIS) and save it to the GML (3.2.1), Esri Shapefile and Mapinfo TAB.
The source table contains multiple geometry columns.
Do those formats and/or writers support multiple geometries.
Best regards,
Damian
Best answer by redgeographics
Shape and TAB don't support multiple geometries, GML does.
Forum|alt.badge.img+63
  • Jun 10, 2019 12:04 PM UTC
Thank you for you answer.
Is it possible to write GML with multiple geometries with PostGIS FeatureReader and GML321 FeatureWriter? Looks like the first column is used as an "object geometry" and other columns are being skipped in the schema feature.
