gz to shp problems
  • June 11, 2018
  • 87 views
I am struggling to get 113.gz os mastermap files to convert over to .shp. I am not that experienced with FME but am finding that the workbench keeps crashing when its reading the files.
Does anyone have any tips? I have found previous docs regarding a translator called Fanout - but doesn't seem to exist in my software.
I would be grateful for any tips as would like to start moving all of our processes over to FME.
Thanks,
Alice
danilo_fme
Forum|alt.badge.img+53
  • June 11, 2018
Hi @alicepalmer
Could you share us the print of your Workspace?
Thanks,
Danilo
Forum|alt.badge.img+62
FME should be able to read from .zip files, presumably .gz too but could you unzip them anyway and try again?
lars_de_vries
Forum|alt.badge.img+10
I think this thread describes the problems your facing and how to overcome them.
  • June 13, 2018
There is no need to unzip the source files. OS MasterMap is a supported GML schema and a Reader format "OS (GB) MasterMap" exists.
Choose New > Generate Workspace
Select input GZ files
Writer format "Esri Shapefile"
Select output folder
Click OK
That will get you started.
