GTFS data to PostgreSQL database
  • May 26, 2020
  • 38 views
Hello,
is there a way to import GTFS data into a PostGreSQL database with FME ?
Thanks for your help.
danilo_fme
Forum|alt.badge.img+52
  • May 26, 2020
Hi @lompui
Is possible to work with GTFS format.
You can see this interesting Post.
Thanks in Advance,
Danilo
  • May 26, 2020
Hello. Thank you. I watched it.
My main problem is to go from FME to a PostGres database.
I don't find any interesting things about this.
Thanks for your help !
@lompui In the article that @danilo_fme referenced, have a look at the example starting at Creating Points for a Shapefile of Stops. Work through that example and instead of Shapefile use PostGIS. I think you'll get the information you need. If you're new to FME then it can really help to attend an instructor lead on-line training class or work through the recorded version.
