Group records in range of Values and time
  • Sep 20, 2024 8:20 AM UTC
  • 162 views
nbeekers
Hello,
Im searching for a solution to give records a group value based on multiple values statements.
Data needs to be grouped on a Vehicle in time asc.
So far this is not the problem.
The grouping also needs to Start with a value Status = "Start”and all the other records after Start.
The grouping needs to be closed after Status End comes as a record.
It looks like a range or a ranking.
If someone has some idea thanks.
Kind regards,
Nick
Best answer by bwn
Leads to AttributeCreator with Adjacent Feature Processing and a Conditional Value that sees if Current Feature = ‘Start’ and previous Feature = ‘End’.  If so Increment Group_ID + 1
bwn
Forum|alt.badge.img+26
  • Sep 20, 2024 9:09 AM UTC
There are a couple of ways.  Personally I would use AttributeCreator with Adjacent Feature Handling since it has flexibility in Conditional Value Rules.
First to make sure of the Sorting needed.
Assuming the rules are, New Group is where:
  • Current Feature “Status” = ‘Start’; and
  • Previous Feature “Status” = ‘End.
Now, use 1 AttributeCreator to create a blank Group_ID Attribute + 1 AttributeCreator that looks at the value of Status for both the current Feature, and the previous Feature.
bwn
  • Sep 20, 2024 11:48 AM UTC
nbeekers
  • Sep 20, 2024 12:43 PM UTC
Thanks for your insights.
Im gonna run the proces with the settings.
