Google Maps KML to TAB not showing user attributes in separate columns
  • Aug 8, 2019 3:53 PM UTC
  • 212 views
I have an editable KML with all its user attributes showing in a data table in Google Maps - showing as above when I click on the map objects. I want to be able to export that data back out of Google Maps to TAB or Excel (or anything!), with all these user attribute fields. However, when I export this from Google Maps and look at the Feature Types of the KML Reader in FME Inspector, there are no User Attributes, only Format Attributes. When I use the Inspector, the attributes look as below - there are no kml_schema_ attributes, only kml_data attributes with name (attribute column heading) and value, each one suffixed 1, 2, 3 etc. So when I use a simple workflow with no transformers to export this to TAB, all user attributes are concatenated into the kml_description field as shown below. I have a feeling this isn't normal...……. My original export to KML for Google Maps was from a Shapefile using QGIS export tool (I removed text from "DescriptionField"), and the data displays as I want it to in Google Maps.
I would be very grateful for any help. Thank you, Jane
Best answer by daveatsafe
Hi @janem,
The kml_data{} list won't be written to TAB, since it doesn't support list attributes. However, we can use an AttributeCreator to convert that list into regular attributes:
Add an entry for each element in the list you see in the Data Inspector.
Workbench doesn't know the contents of kml_data{}.name, so we will need to expose the new attributes, based on our knowledge of the source table. Please add an AttributeExposer, and expose the new attributes:
description
ID
Location
Location_id
Grid_Ref
_10_km_Sq
_1_km_Sq
Easting
Northing
daveatsafe
Forum|alt.badge.img+24
  • Aug 8, 2019 5:37 PM UTC
Hi @janem,
description
ID
Location
Location_id
Grid_Ref
_10_km_Sq
_1_km_Sq
Easting
Northing
  • Aug 9, 2019 9:49 AM UTC
That looks really helpful, thank you Dave. When I get access to FME again next week I shall try this out. Thanks again!
  • Aug 12, 2019 2:25 PM UTC
I followed your advice using the AttributeCreator and AttributeExposer as above and it worked perfectly! Thanks very much - I now have MapInfo table with all my attributes.
