GML xlink:role
  • May 11, 2018 12:29 PM UTC
  • 111 views
Hello,
is there a way to access a value of GML xlink:role property? I can access other xlink properties such as href and title but not this one.
Thanks for suggestions.
trentatsafe
Forum|alt.badge.img+7
Hello @honkovam,
One option that can be used to access the GML xlink:role property, would consist of the following:
1) Add an XML reader with the Feature path set to Geometry.
2) Use a FeatureMerger to merge the GML features with the XML geometry attributes based on the ID. This should allow you to see all features then.
I hope that helps for the time being.
deanatsafe
  • Jun 1, 2018 11:14 PM UTC
Normally we ignore some of these optional schema elements because they are very seldom used. However, if you need access to this, you can carefully modify your gml_config.xml in your FME installation. I recommend backing up the original before modifying anything.
  1. Go to FME2018.0\\xml\\gml_v3.2
  2. Back up your gml_config.xml
  3. Go to line 211 ( in version 2018.0.1) and comment out the role line by replacing '<v>role</v>' with '<!-- <v>role</v> no longer ignore role -->'
  4. Save and restart FME
The next time you add any GML based reader, if your data has xlink:role attributes, then the GML reader should pick them up. If you feel this is an option that should be part of the default INSPIRE or GML readers, I would invite you to add a new Community Idea to that effect. I'm attaching my gml_config.xml as an example. Below you can see a feature being read with xlink:role values:
gml-config.xml
  • Jun 5, 2018 7:34 AM UTC
gml-config.xml
Hi @DeanAtSafe, thanks a lot for your help, works a treat.
