Globally update value from -99 to Blank
  • Feb 26, 2013 12:44 AM UTC
  • 5 replies
  • 68 views
Afternoon All, i have a ESRI file gdb with 20 featureclasses within it. i want to change the value -99 to Blank within all the attributes and all the tables. LIke a global value mapper. Is there any simple solution im missing ?
Thanks Steve
  • Feb 26, 2013 4:07 AM UTC
FME doesn't have a global value replacer. But perhaps you can use the StringReplacer. You would need one for each feature class though.
sigtill
Forum|alt.badge.img+25
  • Feb 26, 2013 5:22 AM UTC
Also you could use a PythonCaller to iterate through all the attributes and replace the values. That way you would not need to specify which attributes that needs replacing.
  • Feb 26, 2013 8:00 AM UTC
Hi Steve,
It would be possible to make something with an AttributeExploder and a looping custom transformer, but a PythonCaller is probably the fastest and easiest solution, as SigTill also suggests. Here is an example:
import fmeobjects   def global_string_replacer(feature):     attributes = feature.getAllAttributeNames()     for attrib in attributes:         value = feature.getAttribute(attrib)         if str(value).strip() == "-99":      # Search             feature.setAttribute(attrib, "") # Replace
It is easy to convert this into a custom transformer where the search and replace strings are given as parameters, if necessary.
To read all the features classes in a File Geodatabase, you could use the reader "Schema (Any Format)" and then pass the list of feature class names to a FeatureReader.
David
  • Feb 26, 2013 9:30 PM UTC
Thanks all for your input. Davids python script is magic. Looks like i will need to delve deeper into python callers in the future.
Thanks David and others
Cheers Steve
  • Feb 26, 2013 10:06 PM UTC
Good to hear it worked, Steve.
The PythonCaller is an incredibly powerful transformer once you "get" it, I can heartily recommend spending some time to understand its capabilities!
Here are some starting points: Feel free to ask here if you have questions on your path to Python mastery with FME!
David
