Getting world file from JPG & CSV files
I have some aerial images that need geotagging from a CSV file. I'd also like to get the world file for each image. I'm new to FME and have tried to read docs/forums on how to solve this problem but am stuck. Appreciate any tips/how to's. Thanks
Forum|alt.badge.img+40
  • March 23, 2020
You will need to read in both the images and the csv file and then use the georeferencer to assign the spatial extents. If you then write the georeferenced images back to a jpg, the world file will be generated.
If you can attach sample files, someone might be able to put a workflow together for you
  • March 23, 2020
