Get row with max value for attribute
  • December 13, 2018
  • 286 views
tfcw
Participant
  • Participant
I have a table with three attributes: NAME, LOCATION, and AREA. I want to get the row with the largest area, for each name. In Oracle, I can do so with this query:
select
    name,
    location,
    area
from (
    select
        name,
        location,
        area,
        max(area) over (partition by name) as max_area
    from mytable
where area = max_area
I could put this into a SQLExecutor, but I'd like to be able to do this even if my data source isn't Oracle.
Can I accomplish this using FME transformers instead?
Best answer by erik_jan
The easiest way to do this:
Use Sorter to sort on attributes NAME and AREA(descending).
Use Sampler to sample the first record, group by NAME.
erik_jan
Forum|alt.badge.img+18
  • December 13, 2018
tfcw
Participant
  • Participant
  • December 13, 2018
Thanks, that worked like a charm
  • December 14, 2018
I agree with with @erik_jan, but an alternative solution more in tune with the orgininal question could be to use the InlineQuerier.
