Get closest value from one set of data on another set
  • Mar 7, 2025 2:19 PM UTC
  • 93 views
4ntoine
Forum|alt.badge.img+3
Hello
Here’s my challenge:
I have two datasets that I need to compare after several transformations.
- Dataset 1: This contains georeferenced points with distances associated with a linear reference system (LRS).
- Dataset 2: This has no geometry, but contains distances from the same LRS.
My aim is to associate each value km_start in dataset 2 with the closest value _measures in dataset 1, even if they don't match exactly (I’d like to be able to assigne a tolerance, for ex. max difference of 0.01m). Thanks to this matching, I will be able to assign a geometry to the data in the second set.
Below are a few screenshots to illustrate my question:
Dataset1 with georeferenced points, _measures are distances in the LRS
Dataset2 with non geometry features I want to get the closest match from Dataset1
We're talking about fairly important datasets but it shouldn't be too much of a problem if the process takes time.
Thank you in advance for your help and ideas.
Best answer by 4ntoine
Hello
I found a much simpler and more direct way of achieving the desired result thanks to a video by Dave Campanas. For those interested, here's the link:
Have a great day
4ntoine
  • Mar 7, 2025 3:03 PM UTC
Hello
Have a great day
