geotiff to tab
  • December 22, 2017
  • 77 views
Best answer by davideagle
Use a Reprojector transformer and when you write to either a Tiff or GeoTiff format, make sure that on the writer's parameters you check the box to generate *.Tab files. Incidentally you can also generate *.tfw world files if needed as if MapInfo sees these it will auto generated the *.tab files itself.
debbiatsafe
Forum|alt.badge.img+21
  • December 22, 2017
Hi @farmangr
Would it be possible for you to provide more information regarding your question? Are you looking for information on how to translate GeoTIFF to tab?
Kind regards,
Debbi
danilo_fme
Forum|alt.badge.img+53
  • December 22, 2017
Hi @farmangr,
I agree with @DebbiAtSafe :)
  • December 23, 2017
Hi@danilo_fme
Project GeoTIFF translate into the projection tab for Mapinfo
davideagle
Forum|alt.badge.img+22
  • December 25, 2017
