Geoparquet Reader on FME Form 2024
  • October 29, 2024
  • 5 replies
  • 97 views
loicgueninrande
Hi @Safe !
I have a probleme with Geoparquet reader on FME Form 2024. It does’t work with the file in attachment but work fine with Apache parquet on FME Form 2023.
The error is :
Thanks for your help.
Loïc
aliatsafe
Forum|alt.badge.img+24
  • October 30, 2024
Hello, @loicgueninrande!
Thanks for posting your question. Before reproducing the issue, I wasn’t able to access your file (access denied). Would you kindly upload another?
Thanks!
loicgueninrande
Hello Ali
Yep, here is the parquet file again
Loïc
aliatsafe
  • October 31, 2024
Hello, @loicgueninrande.
Thanks for providing the dataset. I tried to reproduce the issue on my end with FME Form 2024.0.3 and 2024.1 and did get the same errors.
This is a bug [FMEENGINE-83603], and will be fixed in the next version of FME Form. If you need a workaround as soon as possible, I’d advise to download our latest 2024.2 beta to see if it works there.
Thanks!
josch
Participant
Forum|alt.badge.img+3
  • Participant
  • January 22, 2025
Same here on 2024.1.2.1 (20240906 - Build 24624 - WIN64).
Got a simple tarquet file (not geoparquet) with coordinate-attributes as double type. However, Parquet Reader tries to read type “x_coordinate” and “y_coordinate” and fails with “PARQUET reader: Internal Error: Failed to add point geometry”.
Unfortunately, there seems no way to explicity set the type for the affected attributes manually?!
aliatsafe
  • January 27, 2025
Hi, ​@josch,
Sorry about the troubles you’ve been facing with that build of FME Form. We advise trying to upgrade to 2024.2 if you can as this should address most of the problems around this question thread and possibly yours as well. Let us know if you experience that same issue, and we’ll look into it for you.
Thank you.
