geometry_text_string cannot be converted correctly
  • Dec 28, 2016 5:40 PM UTC
  • 89 views
I have a oracle special data from database one which looks like below, it was a label or a text something.
MDSYS.SDO_GEOMETRY(2001,82232,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,0,6001,11,1,1),MDSYS.SDO_ORDINATE_ARRAY(360.784660012623,0,0,1,131072,16,7209045,7602281,3211296,655373,630758.221843477,5523011.93164305))
and I want to copy it to database two with FME.
I added an AttributeExposer as a transformer to expose oracle_element{}, and added a ListExploder to list _element_index for the oracle_element{}. I also set geomedia_text_font_size to 0 with another AttributeCreater. But the result I got was always something like below:
MDSYS.SDO_GEOMETRY(2001,82232,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,0,6001,8,1,1),MDSYS.SDO_ORDINATE_ARRAY(360.784660012623,0,0,1,65536,4,437918234,630758.221843477,5523011.93164305)).
It seems the source data saved the geometry_text_string with 16 bytes, while the target data saved it in 8 bytes.
My question is that is there any transformer or any way to copy the source data to the destination ?
Thanks.
itay
Forum|alt.badge.img+19
  • Dec 28, 2016 7:15 PM UTC
Hi @whq10whq10, If you are not doing any data transformation and reading and writing from Oracle, I would try to generate a workspace (CTRL+G) using the dynamic setting. That will result if a workspace where the writer schema originates from the reader.
Hope this helps.
  • Dec 28, 2016 9:20 PM UTC
Thanks Itay. Actually, my case will do some data transformation from the source to the target. I tested with dynamic schema you suggested but FME complains Cannot create table within when logged in user is ''". I noticed if there is no format characters in the geometry_text_string, the transformation will be good, but if there is any format characters in geometry_text_string, FME will remove all the format characters so the geometry data is a little bit different with the original, which was not I want. I just want to keep the format characters in the target geometry, but failed after attempting to use all kinds of character, text, or string transformers.
itay
  • Dec 29, 2016 8:08 AM UTC
I would contact support about this issue.
gio
Forum|alt.badge.img+15
  • Dec 29, 2016 3:59 PM UTC
U want to copy the sdo_geometry string to a spatial database?
Update or insert statement as explained in the oracle sdo user guide docs.
Or just push the geometry in..
You can use a sql creator to simply do read the geometry :
select
82232,
NULL,
from dual
If you have it in a attribute
select
@Value(MySDO_attr)
from dual
etc.
and then write the output to database as desired.
