Geometry from Smallworld to Postgres
  • Nov 18, 2013 5:44 PM UTC
  • 88 views
Hello,
I have a problem when I want to migrate Smallworld records to Postgis, I can not migrate the geometries.
When I do the opposite, to migrate PostGis records to Smallworld:
1- I add, the format attribute "sworld_geometry{0}.sworld_name",  in the Smallworld Reader.
2- I put an "AttributeCreator" transform in the workbench and create the attribute "sworld_geometry{0}.sworld_name" with value: location, route o boundary,(they are the names of the geometric attributes in Smallworld,That depends on whether the geometry is a point, line or area)
But i don´t know how can i do the same for PostGis.
Thank You
  • Nov 19, 2013 2:21 AM UTC
I have no experience on Smallworld, but sworld_geometry{0}.sworld_name seems to be one of the Smallworld format attributes. If so, I think you can expose it on the Smallworld reader feature type, or by the AttributeExposer transformer, then write it into a field of the PostGIS table.
Takashi
  • Nov 19, 2013 2:33 AM UTC
Thanks, my problem was that y have the name of the Postgis attribut bad written.
Thanks Takashi
