GeoJSON output order and NULL column
  • Jul 23, 2019 1:59 PM UTC
  • 60 views
connecter
Forum|alt.badge.img+10
Hello,
my first problem: Writing a GeoJSON in the right order. Simple example:
I want a output in the order A,B,C (like I set it in the writer). But the GeoJSON file is A,C,B, because the first row in B is empty.
Second Problem: When the B column is empty. Only A and C is written. How can I get an empty column in the writer?
Thanks for your feedback!
Best answer by takashi
Hi @connecter, I was not able to reproduce the first issue - wrong order of attributes. What version of FME are you using? Could you share a small workspace and source dataset example which can reproduce the issue?
Regarding the second issue - missing B, try assign Null to every missing B with the NullAttributeMapper transformer before writing.
  • Jul 23, 2019 10:47 PM UTC
connecter
  • Jul 25, 2019 5:45 AM UTC
Hi @takashi,
thank you for your answer. Both problems are solved with the NullAttributeMapper. The first issue exists, when B have no entry and it looks like:
"properties" : {
"A" : Hans,
"C" : Berlin
"properties" : {
"A" : Klaus,
"B" : 25,
"C" : Paris
The order of the column is A,C,B. With your help, the NullAttributeMapper create a B with "null".
Maybe the GeoJSON writer get an update with this option? It that case, its makes not much sense.
