Generate numbers in pairs
  • Jun 29, 2020 7:39 AM UTC
  • 7 replies
  • 93 views
sorinduru
Hello,
how to generate numbers in pairs from 2 to 80 and from 3 to 77.
ex: 2, 4, 6, 8,.....80
3, 5, 7, 9,.....77
Nr. 1Nr. 2238077
Forum|alt.badge.img+54
  • Jun 29, 2020 7:59 AM UTC
Why would 80 be paired with 77?
Forum|alt.badge.img+63
You could use a Counter and then use an AttributeManager to multiply the _count value by 2 to get the first sequence, add 1 to that to get the second sequence.
But then the last number of the second sequence should be 81, not 77, so like @ebygomm said, why that matchup?
sorinduru
  • Jun 29, 2020 10:12 AM UTC
Can be even numbers from 2 to 12 and odd numbers from 3 to 23. (i.e. 6 numbers appears in column Nr. 1 and 11 numbers in column Nr. 2) the table posted is only for example.
  • Jun 29, 2020 1:55 PM UTC
But, how do you know what numbers you want to pair? Is it just the last one that's out of order? So in the 2-12 and 3-23 one, do you want:
2345678910111223
Or what pairing do you want? If you know the formula, i.e. the relation between the lower number and the higher one, then @redgeographics is on the money. Otherwise, if you know each numbers buddy-number (i.e. the odd one), using an AttributeValueMapper might be useful. Can you clarify what the relation is between the two sets of numbers?
sorinduru
  • Jun 29, 2020 2:34 PM UTC
I've simplified the problem a little bit, and I have the following data:
NAMEA_MINA_MAXB_MINB_MAX
X212311
Y466187
Z1458745
Where A column contain only odd numbers and B contain only even numbers
Where A_MIN it represents the lowest even number and A_MAX represents the highest even number.
same with B_MIN and B_MAX.
I'm thinking about two types of results:
1.
NAMEA_MINA_MAXA_COUNTB_MINB_MAXB_COUNTX2126373Y41041116Z142047155
Or:
2.
NAMEABX23X45X67X81X103X125Y47Y69Y811Y107Z149Z1611Z1813Z2015
  • Jun 29, 2020 2:45 PM UTC
X212311
Y466187
Z1458745
1.
Or:
2.
Excellent! So, for result 1) you can rely on this formula:
Number_diff = (Max-Min)/2 + 1(you'll need to add 1, since you're also including the upper bound). I.e. (A_MIN - A_MAX)/2 +1 = A_COUNT -> (12-2)/2 = 5, 5+1 = 6 = A_COUNT.
For 2) I'll try to get a small example workspace for you. However, is it correct that f.ex. the 4th row (X 8 1) has Name = X? Seeing as we've "run out" of B-values for feature X. I'll trust that your example is right though, and proceed as such.
  • Jun 29, 2020 3:25 PM UTC
Self-reply: See if this is useful @sorindurutable_pair_builder.fmw - I've built it in 2020.0, hope that's good for you.table_pair_builder.fmw
