From (Latitude,Longitude) to (X,Y) in EPSG:32717,
  • April 4, 2014
  • 73 views
Hello,
I´ve a little problem.
I have latitude and longitude coordinates in decimal degrees but i need them with decimal values in EPSG:32717 (UTM-WGS84 17S) for x and y. x=667876.12 and y = 1234564.345 for example
How can i do this?
Thank You
Best answer by takashi
Hi Lucho,
The AttributeReprojector might help you.
Takashi
  • April 4, 2014
Hi Lucho,
Takashi
  • April 4, 2014
thanks...but i don´t know what coordinate system is the source. I supose that the last coordinate system is EPSG:32717...but the first?...
  • April 7, 2014
You can try with EPSG:4326 (or "LL84" in FME, they are the same thing).
David
