Frequent problems reading PDF documents as raster
  • Feb 23, 2021 9:42 AM UTC
  • 62 views
I often get this messeage when I try to read PDF documents (floor plans) as raster. When I try to read the same PDFs as vector it works fine. But I just want to read the PDFs as raster because I want to convert the PDF documents to the PNG-format. How can I avoid this message? My estimate is that I can only read approximately 25% of the PDF documents I would like to read.
I use the featureReader to read the "Adobe Geospatial PDF"-format.
feilmelding
The log says: Merged 0 schema features read from 1 datasets into 0 resulting feature types
UniversalReader -- readSchema resulted in 0 schema features being returned
daraghatsafe
Hi @henrikandersson​ is this just with the feature reader or does this occur with the PDF reader also?
Thanks, Daragh
