FME Workbench 2007: how to execute sql statements using feature attributes
  • Jun 14, 2019 7:10 AM UTC
  • 65 views
dms2
Forum|alt.badge.img+11
One of our customers still uses v2007 of FME Workbench and I'm having a bad time trying to do what I find so easy with latter versions.
Workbench help doesn't help much and I can't find examples on the internet so if anyone has a clue on how to do it I'll be very grateful.
I want to use attribute values in sql statements but SQLExecutor transformer in FME v2007 looks too basic and I don't know if it's even possible to do such a thing. The image below shows what I tried and doesn't work at all. I get error: BADNEWS: Database Writer: Commit failed -- [NOTSUPPORTED] commitTransaction not supported by core library
  • Jun 14, 2019 7:17 AM UTC
It's not the answer you're looking for, but you should really, really try to convince the client to upgrade. FME 2007 was retired about 7 years ago and is no longer supported by Safe.
As long as the client has a valid maintenance contract, upgrading is eas easy as downloading and installing:
https://www.safe.com/support/support-resources/fme-downloads/
PS: For the problem, try using only a single SQL statement (split it up into two different SQLExecutors) and skip the semi-colon at the end of the statement.
dms2
  • Jun 14, 2019 8:37 AM UTC
Unfortunately it's not in my hands to try to convince them.
On the other hand I tried your suggestion and it doesn't work.
Thank you anyway.
