FME - why is tif writer is setting 0's in any band to NODATA?[ e.g. (0,16,0)>>(NODATA, 16, NODATA) ]
  • April 19, 2014
  • 30 views
makt
I'm reading a geotiff and am unsure why when I'm writing to a new geotif, all my dark dark green cells, such as RGB (0,16,0), get rewritten to (NODATA, 16, NODATA).
Using the RasterBandNoDataRemover does fix the problem, but also changes the NODATA cells that I want to be NODATA into balck (0,0,0).
How can I fix this? Seems to me that this should not be a default behavior...
  • April 20, 2014
Hi, the RasterCellValueReplacer transformer might help you.
Takashi
gio
Forum|alt.badge.img+15
  • April 22, 2014
Appearently 0 is nodata in your set.
RasterBandNodataSetter or replacer might be usefull.
makt
  • April 25, 2014
After looking over all the options, the easiest options seems to be using RasterExpressionEvaluator.
