Is there a setting somewhere that dictates the maximum file size that can be uploaded by the file upload service on FME server 2013?
We are finding that anything larger than 27mb will cause an error, even though we have changed the tomcat configuration to allow a maximum file size of 100mb to be posted.
Thanks,
Andy
what setting did you change in the Tomcat config?
If it wasn't maxPostSize, have a look here.
Also, what does your Tomcat log say? Try enabling debug mode and see if there is any mention in the log.
David
Hi David,
I did set the maxPostSize in conf\\server.xml, and the <max-file-size> in webapps\\manager\\web-inf\\web.xml. Both set to 100mb.
I couldn't see anything in the Tomcat logs that was different between a file that worked and one that didn't, other than there is no return from the file over 25mb. I'm not a Tomcat expert and am waiting on some help from out IT guys to look in to it further.
Thanks,
Andy
We tracked the issue down to a setting in IIS.
In addition to the steps described in the safe article on setting up ARR you must go to the "Request Filtering" settings for the IIS server in IIS Manager, select "Edit Feature Settings" and change the "Maximum Allowed Content Length" to the same lenght as used for Tomcat.
