FME Server: Read/Write from UNC path
  • Aug 19, 2015 7:15 AM UTC
  • 151 views
Hi everyone!
I have a simple workspace that I published to FME Server Jobsubmitter: it reads a textfile from a shared UNC path and logs each line. I have configured a specific user FME_Server_User that starts my serverjobs. If I log in as FME_Server to the server, I can access the specified folder and file and modify it or whatever. I can also run the workbench in FME Desktop without a problem. As soon as I start the job from FME Server Repository GUI, it fails.
I get following error:
Text File Reader: Source dataset '\\\\shared\\test.txt' does not exist
A fatal error has occurred. Check the logfile above for details.
The problem occures in a newly created folder on the share. The old folders still work just fine with the same setup (FME_Server_User etc.).
Thank you very much for your help!
  • Aug 19, 2015 9:37 AM UTC
Hi
First of all, make sure that you've read through this: https://knowledge.safe.com/articles/Error_Unexpected_Behavior/Workspace-Fails-on-FME-Server-When-Using-UNC
If the problem persists, have your network administrator verify that the user account that runs the FME Server engines have sufficient rights to the newly created network folder.
David
