FME-Server/Engine: Output directory
  • Dec 21, 2012 12:14 PM UTC
  • 80 views
mhab
Forum|alt.badge.img+10
Hello
If I run a workspace on FME Server through an FME-Engine, and
- if this workspace writes some output,
- and the output is specified without a path
    e.g. write DXF to "test" ...
--> then the output is written to the FME-Server Repository directory, which is NOT where I prefer to get the result.
Is there a way to specify the working dir for the engine at runtime, like with a parameter ?
I found FME_WORKING_DIR in the engine configuration, but it seems to be static.
Thanks for any advice
Michael
sigtill
Forum|alt.badge.img+25
  • Dec 21, 2012 3:50 PM UTC
Hi Michael!
You are looking for the "temp" directory for each transaction: Called: FME_SERVER_DEST_DIR. More information here:
http://fmepedia.safe.com/articles/Error_Unexpected_Behavior/Dataset-Fanout-doesn-t-work-for-Services
mhab
  • Dec 21, 2012 4:05 PM UTC
Hi Sig
Thanks for the hint. This should solve my problem.
Additional question is, if I can specify the FME_WORKING_DIR in some way if I use the FMEServerConsole to run the workspace.
Background: Most of my workspaces are used in both FME-Desktop and FME-Server environment and I am reluctant to publish a parameter FME_SERVER_DEST_DIR and then use the workspace in a desktop enviroment ?!
sigtill
  • Dec 21, 2012 6:26 PM UTC
I have used Scripted Parameters to successfully have a workspace seamlessly run on both Desktop and Server without needing to change anything on the Published Parameters.
http://evangelism.safe.com/fmeevangelist72/
