FME Server custom log file location
  • Oct 10, 2017 2:55 AM UTC
  • 277 views
nic_ran
Forum|alt.badge.img+20
We are seeing an increasing number of clients wishing to manage log files using a central log collection and monitoring system. By default, FME Server stores all log files in the system share directory structure but this also contains repository information, etc.
I would like to move just the log files (not the whole system share) to another location. Has anyone done this? It looks like it should be possible by editing a few settings in the fmeServerConfig.txt file but it's probably not recommended...
Bonus question: how nicely would these changes play with a fault tolerant (Active-Passive) architecture?
Best answer by jlutherthomas
hi @nic_ran
I definitely do not recommend editing the configuration files to change the log file location. This is specified at install and cannot be changed. Our documentation references this here: https://docs.safe.com/fme/html/FME_Server_Documentation/Content/ReferenceManual/About_Log_Files.htm
You could maybe set something up that could copy those logs into a desired location, so FME server could still access it and it'd be in a desired location for other uses.
hi @nic_ran
  • Oct 10, 2017 7:34 AM UTC
hi @nic_ran
I agree, I once inherited an old FME Server installation where they'd done just this and it was always such a pain. It was a major relief when we redid their architecture and stuck to the default settings.
nic_ran
  • Oct 10, 2017 11:07 PM UTC
hi @nic_ran
Hi @jlutherthomas,
thanks for your response. I had read the relevant section of the documentation and already understood that it was not recommended. :)
Perhaps this could be considered as a future enhancement for FME Server? I'll post it up on the ideas board.
Nic
