FME Server Custom Error
cwarren
Some of my workspaces contain multiple checks before any data is processed and are hooked up to some Terminator transformers. Is there a way to show the custom error message, that is included in the Terminator, in the web gui instead of the default translation failed message?
Although the terminator message is in the log file, I would prefer the message be shown to the end user instead of having to access the log file.
FME Server 2018.1
Best answer by redgeographics
If you set up your workspace to have data streaming output you can generate HTML to show to the user. Actual writing of data can be done using FeatureWriters
Forum|alt.badge.img+50
  • March 14, 2019
cwarren
  • March 15, 2019
That actually seems like a good work around! I also found an idea that was posted about the terminator transformer.
https://knowledge.safe.com/content/idea/22972/terminator-improvements.html
