FME Server and SBS Plugin
  • September 30, 2013
  • 138 views
To automated the running of my workspaces I have installed the FME Server.
Basicly the purpose of the jobs is migrate smallworld to a newer smallworld version.
However every time running through the FME Server, the message bellow appears:
Failure
This FME edition does not recognize the `SPATIALBIZ' reader. Please ensure that the current platform supports this reader, the reader name is spelled correctly, and that you have installed all required plug-ins
I can't understand why once my FME Desktop is licensed for SBS plugin correctely and ran the workspace manually with out any problem.
There is some thing to do on FME Server directory? (As test, based on this articlehttp://fmepedia.safe.com/articles/How_To/Installing-a-SpatialBiz-Smallworld-reader-writer-floating-license, I have copied the sbs.lic file and pasted into C:\\apps\\FMEServer\\Server\\fme\\licenses directory, however the error persists).
Could some one help me?
Best answer by david_r
I suggest you contact Safe support with licensing issues. It could be a good idea to also attach both license files when writing them.
David
  • October 1, 2013
David
