FME reads .dbf wrong?
  • Jan 31, 2023 9:47 AM UTC
  • 10 replies
  • 122 views
anne_kathr1ne
I have a dataset in .dbf format, with 885 rows. When I read the file in FME it reads the 885 rows, but when I use the DuplicateFilter it tells me I have 330 unique rows and the rest are duplicates.
But actually all these 885 rows are unique, I can see that when I look at the file using ArcGIS Pro, and my colleague have looked at the file in another text-application. So it seems FME keeps the total number correct, 885, but changes some unique numbers so they are duplicates somehow.
In AGP:
imageIn FME:
How can this happen? I have tried reading the file both using the "normal" .dbf-writer, as well zipping the file and using Creator > ParameterFetcher > FeatureReader > FeatureReader > AttributeExposer.
nielsgerrits
Forum|alt.badge.img+67
Hard to say without data :)
How is the DuplicateFilter configured?
anne_kathr1ne
  • Jan 31, 2023 11:20 AM UTC
Hi @nielsgerrits​
I have added data here.
nielsgerrits
Hi @nielsgerrits​
I could reproduce your issue in FME. When I open the file using Excel or QGIS I see the same results, but can't open it in ArcGIS Pro.
Not sure what is wrong here. Is it a possibility that the file is open in an edit session in ArcGIS Pro, which has a lock on it? Or not saved edits?
It feels like the issue is not in FME / Excel / QGIS, but rather something else is wrong. I have seen people edit the dbf of a shapefile set using Excel causing weird issues like this, not sure if this causes your issue.
You always can try to export the data from ArcGIS Pro to a new file to see if the problem goes away.
anne_kathr1ne
  • Jan 31, 2023 1:19 PM UTC
Hi @nielsgerrits​ ,
good that you were able to reproduce.
I didn't have the dbf file open in ArcGIS before I needed to check it, so I don't think it can be that. I could of course try to export it from there, but I am building a FME- script that will be published to the server, and it will read dbf-files directly. The script is developed so that other people can do the update (without any pre-processing). So really need to figure this out.
rahulsharma
Forum|alt.badge.img+12
Hi @Anne Kathrine Wenaas Ribe​
Can you open the file in Text Editor such as Notepad++?
anne_kathr1ne
  • Feb 1, 2023 8:28 AM UTC
Hi @rahulsharma​ ,
The file I uploaded was a "stripped" one without sensitive data. When I open the original file I can see the unique values.
@nielsgerrits​ : I was also able to open it in excel, was it the duplicates you saw there or the unique values? I see the unique values.
Since I can't share the original data Im not sure if you need to test anything more. I might have to proceed to figure out a solution for this.
nielsgerrits
Hi @rahulsharma​ ,
If I open the uploaded .dbf in Excel or Notepad++ I see duplicate values, so I suspect your sample file is different from the file in the printscreen in ArcGIS Pro.
rahulsharma
Hi @rahulsharma​ ,
Yes, I get a similar result at @nielsgerrits​ i.e. duplicate values when I open the data in Notepad++
Can I request you @Anne Kathrine Wenaas Ribe​ to open the attached data (not the original you have as I can not vouch for that dataset) in the notepad editor?
If you think it is happening to your dataset (a number of tables) we can follow up via a support ticket instead?
anne_kathr1ne
  • Feb 2, 2023 7:42 AM UTC
Hi @rahulsharma​ ,
Hi @rahulsharma​ ,
I opened my original file in notepad++ and it looks correct there with all the unique values. So it seems multiple softwares reads the data correct, besides FME.
I asked my project manager if it was okey to share my original data with you, as the copy I made is not a good representative. That was ok, so Ill make a support case from it.
jdh
Forum|alt.badge.img+41
  • Feb 2, 2023 6:37 PM UTC
I had a different problem with certain shapefile dbfs, where a random amount of features had a value of 0 in FME instead of their actual values as seen in QGIS and Arcmap. Reported as C685504 - Shapefile attributes not returning correct value
This bug was present in all versions of FME 2020-2022, but not present in FME 2019 (build 19813), and also fixed in FME beta 2023 (build 23210).
Can you try the workflow in the 2023 beta?
