FME Google Sheets Writer failing?
  • January 30, 2018
  • 22 views
Hi There!
We are having issues with the Google Sheets Writer timing out and failing. I worked with someone in Support & they were really helpful - but we didn't solve it. My boss was wondering - could it be a firewall issue on our side, and if so what ports need to be opened up to communicate?
Thanks so much! Christen
Best answer by LizAtSafe
Hi @cmcnamara,
It could very well be a firewall issue. Here is a list of the Ports and URLs used by FME.
Specifically here are the Google related URLs (there might be more undocumented URLs, but try these first)
Hope that helps,
-Liz
LizAtSafe
Forum|alt.badge.img+18
  • January 30, 2018
Hi @cmcnamara,
Hope that helps,
-Liz
