FME Form Ubuntu 22.04 synology file server permission problem
  • May 12, 2025 2:00 PM UTC
  • 5 replies
  • 213 views
shamoneau
We are trying to use a FileCopy Transformer to transfer files from one location to our server (synology) / other computers (other computer).
If we do it in Ubuntu GUI / SystemCaller command it works perfectly.
But the file copy transformer always give error messages as we don’t have sufficient permission. Even if I put our NAS credential in the transformer (with a featureWriter), it give the error messages. The files are created in the server but there’s no content inside.
Does somones already experienced it ?
Thank’s
Sam
shamoneau
  • Jul 31, 2025 9:48 AM UTC
Thank’s
Sam
In addition to the problem, the geopackage transformer is unable to write on our server. the file is created but there is no data inside.
OGCGEOPACKAGE writer: sqlite3_exec(COMMIT) failed: database is locked
itsmatt
Forum|alt.badge.img+48
  • Jul 31, 2025 11:25 AM UTC
Are you trying to move or copy the files? or do you get the problem in both scenarios?
How are you running the workspace? Via Workbench or via the terminal calling the fme executable directly?
It looks like the folder you want to write to has write permissions, however, the created files are not editable.
Could there be some weird setting somewhere creation of files is allowed but modification is not?
shamoneau
  • Jul 31, 2025 1:50 PM UTC
I’ am running the workspace directly.
The strange fact is that some writers are working correctly, like the shapefile writer.
We are trying to find if there is some parameters to change but we don’t find anything.
itsmatt
  • Aug 1, 2025 7:30 AM UTC
Yeah, I suspect (not sure though) that there may be certain logic steps in with certain writers that will first create a file and then use another file handler to edit it. For example for shapefule I suspect that because each file is it’s own feature type it will only need to create the file once (and write the data at the same time). Other formats, like geopackage which support multiple features times in the same file may require editing various parts of the file post creation.
The filecopy for me it strange though - I can’t see why an empty file would first get created.
After creating the files what are the permissions on empty files? is the user running “fme” able to edit these files post creation in the terminal at all  - i.e., can you call “touch” on the files?
shamoneau
  • Sep 12, 2025 7:40 AM UTC
hi,
I’ve found something for the geopackage problem.
While i’m running FME on a Ubuntu OS and trying to work on permanently mounted network drive. I added an option in my fstab file.
sudo nano /etc/fstab
for each mounted drive the option nobrl should be there. Now I can write Geopackage correctly with FME.
But there is still a problem with the FileCopy writer. Normaly, the problem as been reported to Safe. I hope they will find a workaround.
