FME Cloud and Azure SQL Server Database Table Read/Write
  • Feb 8, 2018 4:50 PM UTC
  • 64 views
austinh
Forum|alt.badge.img+4
I have created a SQL Server in in Microsoft Azure with a database containing a table with of int, float, varchar and datetime data types.
I have a workbench (2017.1) that is using a FeatureReader and the Microsoft Azure SQL Database Non-Spatial to read data from Azure SQL Server and write to a shapefile.
his works great in desktop, however when I publish this to FME Cloud I get the below error.
Module 'MSSQL_AZURE_SPATIAL' is unavailable for use with this FME edition
I know FME Cloud does not run Microsoft Server
Is there a way to read Azure SQL Server database tables in FME Cloud?
Best answer by gerhardatsafe
Hi @austinh,
On FME Cloud you can user our JDBC versions of all Microsoft SQL Server related Readers and Writers:
https://www.safe.com/integrate/microsoft-azure-sql-database-non-spatial-jdbc/
https://www.safe.com/integrate/microsoft-sql-server-spatial-jdbc/
https://www.safe.com/integrate/microsoft-sql-server-non-spatial-jdbc/
Let us know if you have any other questions!
Hi @austinh,
