FME cant read ESRI gdb,but can writer
  • Mar 29, 2024 2:41 AM UTC
  • 5 replies
  • 137 views
charry
Forum|alt.badge.img+5
nielsgerrits
Forum|alt.badge.img+67
It is always nice to include a bit more information with a post. To try and guess your issue form this screenshot is a bit inconvenient.
FME version?
ArcGIS Pro version? (3.0.2?)
Which reader? (Esri Geodatabase (File Geodb) / Esri Geodatabase (File Geodb Open API))
Which writer? (Esri Geodatabase (File Geodb) / Esri Geodatabase (File Geodb Open API))
What data type? (Points / Lines / Polygons / Annotations / Rasters)
charry
  • Apr 1, 2024 12:29 AM UTC
charry
FME version?
Sorry, the information provided is not very complete, I use arcgis pro 3.02, reader used ESRI' File Geodb, I tried to change ESRI arcgis compatibility, and python option all failed to read, can only write
Forum|alt.badge.img+63
Can you try the OpenAPI Geodatabase reader and see if that makes a difference?
hkingsbury
Forum|alt.badge.img+73
  • Apr 2, 2024 1:06 AM UTC
Is it just an issue with that one GDB? Can you open in the version of Pro you have installed?
