FME can not update ArcFM SQL Server database
  • Oct 31, 2017 9:46 PM UTC
  • 49 views
Hi, I am just doing an simple update on 10.2 ArcFM database using FME in an edit session. It gives me an error: The error number from ArcObjects is: '-2147467259'. The error message from ArcObjects is: {}. I can not figure out why.
todd_davis
Forum|alt.badge.img+23
  • Nov 1, 2017 3:33 AM UTC
Can I firstly confirm that you are using that the layers you are using ArcFM objects rather than Esri? If so, are you using the ArcFM license as part of your process to update the data...
https://knowledge.safe.com/articles/582/using-fme-to-write-to-arcfm-geodatabases.html
