FME adds @ in front of excel formulas at writing
  • Oct 1, 2025 2:36 PM UTC
  • 158 views
hlynur
Forum|alt.badge.img+10
Hello, its me again.
So I’m playing with changing excel documents in Form 2024.1 and its going superb, except from the fact that when Form writes out my changed excel it adds an @ in front of some of the formulas. So for example the formula that gets read in as:
=XLOOKUP(blabla)
Gets written out as:
=@XLOOKUP(blabla)
Which then makes the whole outcome excel document breaks.
I have ran this with caching and see that at last cache before writing then the formulas are intact, so this must happen in the writer or that the excel gets written out in some manner that my excel setup *misunderstands* it?
As always, all comments are welcomed (as long as you not a person just looking to score some points by copy/pasting what AI said the problem was).
-Hlynur
Best answer by hlynur
Figured out a solution by myself, ok maybe not a solution but a comfortable workaround:
Changing a cell entry in an overly complex Excel document | Community
geomancer
Forum|alt.badge.img+71
  • Oct 1, 2025 3:16 PM UTC
Do you use attributename.formula for your formulas, as mentioned in the documentation under Formulas?
hlynur
  • Oct 2, 2025 3:51 PM UTC
Hey ​@geomancer and thanks for the response.
I’m not even doing that complex thing as to create formulas with Form.
I’m inheriting all formulas written out from the writer, leaving them completely untouched in the workspace while just changing a single number in a cell that only contains that number. Have both tried to write the whole thing out as a fresh document and just done a update command to a existing document, both fail through those @’s being added.
-Hlynur
hlynur
  • Oct 2, 2025 5:56 PM UTC
