FME 2020: How to filter dwg file based on lines and polylines?
  • November 15, 2021
  • 36 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out how to filter dwg file based on lines and polylines
Clip_1133
Best answer by andreaatsafe
Hi @jamal​ ,
Try exposing the attribute "autocad_original_entity_type" and use a TestFilter to filter for autocad_line and autocad_polyline (or autocad_3dPolyline). That attribute should differentiate the line types.
-Andrea
andreaatsafe
Forum|alt.badge.img+10
  • November 15, 2021
Hi @jamal​ ,
-Andrea
jamal
  • November 16, 2021
Thank you for the help. It works fine
Clip_1135
