FME 2015.1 fails to write polygons from AutoCad to file geodatabase correctly
  • Jun 22, 2015 5:57 PM UTC
  • 89 views
ahmad_saleh
Hello All,
FME 2015.1 fails to produce the expected results, I have developed a workbench that mainly convert hatches form AutoCAD to polygons (Esri Geodatabase (File Geodb API)) writer.
But the FME fails to write the polygons correctly, In the attached AutoCAD file I have one single hatch that should be transformed to a polygon and stored in a feature class, after running the workbench I found that the FME fills an empty gap with an extra polygon.
Link to download the workbench and the autocad file
http://www.mediafire.com/download/3axz2lccdnn0d3d/CADToGIS.zip
Best regards,
Ahmad Saleh
Best answer by pratap
Instead of "Deaggregator" Place "AreaBuilder" with "Drop Holes" as "Yes".
pratap
Forum|alt.badge.img+12
  • Jun 24, 2015 6:53 AM UTC
ahmad_saleh
  • Jun 24, 2015 7:30 AM UTC
Hi Pratap,
Many thanks for your replay, " Replacing the Deaggregator by “AreaBuilder with "Drop Holes=Yes" works fine with me and solved the issue.
Thanks
Ahmad Saleh
ahmad_saleh
  • Jun 28, 2015 10:51 AM UTC
Hi pratap,
Its seems that the area builder removes fields such as fme color and autocad color, what is the best practices to keep these fields, is the attribute keeper does the job?  because I failed  to do so.
Thanks,
Ahmad Saleh
