FME 2014 Postgre. authentication failed when query with SQL
  • May 15, 2014
  • 14 views
Having some problem using SQLExecuter and SQLCreator with a Postgre/Postgre.
Error connecting to PostgreSQL database(host='**.***.**.***', port='5432', dbname='*******', user=postgre, password='***'): 'FATAL:  password authentication failed for user "postgre"
Its not really a authentication error since both the postgre and postgis reader and writer works fine with the same credentials. I can connect to the tables in the SQL transformers but when I hit run I get "authentication failed"
Anyone have an clue?
cheers
Henrik Rinne
Best answer by david_r
your question is strangely similar to the one below about SQL Server...
I just tested this with FME 2014 SP1 and postgresql 9.0 on Windows 7, and I had no problems using the SQLExecutor using the same connexion parameters as for the Postresql reader.
David
  • May 15, 2014
David
