FME 2012 compatibility with mapinfo
  • Aug 11, 2014 4:43 PM UTC
  • 60 views
francis_m
Forum|alt.badge.img+9
Hi
We are testing FME 2012 (32x) with MapInfo v12 on WIN7.
When I want to extend MapInfo V12 with the FME Integration Console, I can't do it.
It says I have to upgrade my licence.
Is FME 2012 sp4 compatible with Mapinfo v12?
If not, we are also testing FME 2014 soon.
Is FME 2014 sp2 compatible with MapInfo v12?
Thank you!
  • Aug 12, 2014 9:11 AM UTC
Unless someone from Safe chimes in here, you might want to pass this question on to Safe support (https://safecommunity.force.com/knowledgeSubmitCase) for an official answer.
David
  • Sep 2, 2014 4:52 PM UTC
Hi again
If you look at http://fmepedia.safe.com/articles/FAQ/Build-Numbers-for-FME-Versions then
FME 2013-SP1  is build  13450, and
FME 2013          is build  13264.
Based on the error message I received, the minimum FME version for integration with MapInfo 12 must be FME 2013 SP1.
Philip
