FlexLM Flexserver issues on Debian 8 (jessie) - no such file or directory
  • Jul 17, 2017 9:58 PM UTC
  • 283 views
fmelizard
Forum|alt.badge.img+22
When invoking lmutil or lmgrd an error "no such file or directory" is returned.
Investigation yields that lmutil is using the following interpreter: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-lsb-x86-64.so.3, for GNU/Linux 2.6.9, stripped.
What can I do?
rylanatsafe
Forum|alt.badge.img+14
After contacting Safe Support with this issue, a very knowledgeable and helpful FME User identified that ld-lsb-x86-64.so.3 doesn't exist on a standard Debian installation.
The resolution was to create a link:
ln -s /lib64/ld-linux-x86-64.so.2 /lib64/ld-lsb-x86-64.so.3
The following systemd unit file might also be particularly helpful:
[Unit]
Description=FlexServer - FME Floating Licence Server
After=network.target
[Service]
Type=forking
User=flexserver
ExecStart=/opt/FlexServer/FlexServer11_13_1_3-linux-x64/lmgrd -c /opt/FlexServer/safe.lic -l /var/log/flexserver.log
[Install]
WantedBy=multi-user.target
  • Jan 22, 2018 4:07 PM UTC
