Flatten File
  • Mar 8, 2018 11:22 PM UTC
  • 32 views
I've got output from 3 statscalculators coming together to create the following and was wondering how I could 'flatten' it such that that one record exists for each community and <missing> values have a value of zero.
So the output would look like the excel image.
Best answer by takashi
Hi @aviveiro, the Aggregator (Group By: COMMUNITY, Accumulation Mode: Merge Incoming Attributes) might help you. Then, to assign zero to missing attributes, consider using the NullAttributeMapper.
  • Mar 9, 2018 6:00 AM UTC
  • Mar 10, 2018 2:58 AM UTC
Terrific @takashi !
Your suggestions worked.
Thank you.
