Find a way to convert a point fgdb file with attachments and write to sqlserver
  • Feb 17, 2023 10:40 PM UTC
  • 72 views
masonb12
Forum|alt.badge.img+15
Is there a way to convert an fgdb point file with attachments to sqlserver? Should the photo attachments be stored outside of sqlserver in a separate file? I can convert the point file but how to handle the associated attachments is the problem.
thanks
daveatsafe
Forum|alt.badge.img+24
  • Feb 21, 2023 10:29 PM UTC
Hi @masonb12​,
SQL Server allows columns of type varbinary_max, which can store your photos as binary data.
One approach would be to use an nvarchar column to store the image name and a varbinary_max column to store the binary of that file. These columns can be populated from the ATT_NAME and DATA fields of the _ATTACH table in the GDB.
When adding the GDB reader in FME, uncheck the Ignore Relationship Info button in the reader Parameters. You will need the info in the _ATTACHREL relationship table to merge the attachments onto the points before writing to SQL Server.
masonb12
  • Feb 21, 2023 10:38 PM UTC
Hi @masonb12​,
Ok thanks, will give that a try!
