Find a bunch of dwg files and write to SHP
  • March 30, 2020
  • 61 views
ronmak
Forum|alt.badge.img+5
Currently trying out FME in demo mode and am definitely green at FME so this is a beginner question.
I currently have a workbench setup to read a single dwg, run it through a tester to filter out only the desired layers, and then write it to shp format with the dwg_name and layer_name as attributes.
I have also discovered the PATH reader which I have configured to search a drive and all sub-folders to generate a list of all of the dwg files I want to run through the above.
How do I combine them?
There is a related question 80618 "How to iterate through a list of .dwg file in order to convert them to .shp format" but I am not quite following it, and I have multiple sub-folders.
oscard
Forum|alt.badge.img+22
  • March 30, 2020
If I have understood your goal, you need to do the following:
Add PATH Reader to get the path of al the *.dwg files of your folders and subfolders.
Add a FeatureReadr. Join the output of the PATH Reader to the FeatureReader. Configure the FeatureReader to read DWG files. The path of each dwg is given by the attribute "path_window" of the PATH Reader.
Add a SHAE Writer and join the output of the FeatureReader to it.
