File Geodatabase to IFC
  • March 3, 2016
  • 137 views
I want to convert a building of 3D Multipatch features in a File Geodatabase (ArcGIS) to IFC file to be used in AutoDesk Revit. Is it possible to do so? Thank you.
Best answer by marko
To write to IFC you have to change the data quite a bit, I found a tutorial and managed to tweak the workspace to my needs. You might have to prepare some attributes to create height, unique ID and floor level. Its not immediately obvious from the support but I hope the tutorial below helps.
attribexample
AutoCAD to IFC Conversion Example
Forum|alt.badge.img+5
  • April 1, 2016
attribexample
