File copy Writer -Error on invalid destination parameter not working
raaaju1990
I'm using file copy writer to copy gdb from source location to destination. I'm using file copy writer for this. One of the parameters in this writer is Error on invalid destination which I have set it to NO. So, this means that, if there is no valid destination location found, FME should proceed further without terminating the translation (This is according to the documentation). But, this doesn't happen.
So, how can I handle the error and proceed further with the translation without terminating it.
Could anyone provide some suggestion on this?
pratap
Forum|alt.badge.img+11
  • May 20, 2019
Have you passed the values of all the below attributes...
a. filecopy_source_dataset
b. filecopy_dest_dataset
c. filecopy_dest_filename
raaaju1990
  • May 20, 2019
Yes, I have passed and it works fine. But in worst case scenario, suppose the destination location is invalid or not accessible due to any reason, I want the fme to proceed further without terminating the entire process.
pratap
  • May 20, 2019
To my understanding... If destination folder does not exists then FME will create folder as per the path you have provided
nielsgerrits
Forum|alt.badge.img+55
If the issue is the termination of the entire proces you might want to change your "Rejected Feature Handling" setting from "Terminate Translation" to "Continue Translation".
You can find it in the Navigator under Workspace Parameters, Translation.
raaaju1990
  • May 20, 2019
Suppose in case, the folder is not accessible or if there any network issue with the shared folders, at that time I want the process to proceed further without copying the files. For this purpose I'm trying to use this option -Error on invalid destination which is available as a parameter in the writer and I have set this to NO
raaaju1990
  • May 20, 2019
I tried this option. But, not working as expected. Its terminating the translation
jovitaatsafe
Hi @raaaju1990,
I can't seem to reproduce the behavior where the translation terminates due to an invalid destination with "Error on Invalid Destination" set to "No". It seems to work as expected for me, completing successfully, and logging warnings that I need to check my file permissions to write to the destination folder.
Would you be able to share you full logfile and perhaps a sample workspace as well?
