Supported data types are depending on data format. If "time" type doesn't appear in the drop down list, you can think that the format doesn't support the type.
Hi @adnanyazdani That depends on the file format of the writer you are using.
I am just guessing here but it looks to me like you are trying to write in an ESRI File Geodatabase?
Are you using the File GDB Open API writer? Then I do not think there is an option as time only is a newer field type for ESRI and GDBs
Below is a pic from a File Geodatabase Writer (not the Open API version) so time is an option. Again this all depends on the type of file you are trying to write. Hope this helps.
If the destination format doesn't support "time" type, it's a general alternative to treat a time value as a text. Is there any problem if time values are stored in a text type field of the destination dataset?
I was using ESRI Open API because I was getting an error
How can i resolve this error when i use Esri Geodatabase (File Geodb) transformer
Thanks Again
Well then…. Do you have access to the full File Geodatabase Writer in FME? You will have to have an active ESRI License to use this and that is a licensing thing not a software capability thing.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
