FGDB read error - the error number from ArcObjects is: '-2147220893'
  • October 10, 2019
  • 7 replies
  • 794 views
sam_tw
Forum|alt.badge.img+3
Hi, does anyone have any experience with the following error: -
"Unable to connect to the File Geodatabase at '------'. Make sure the correct filename was specified, and that the geodatabase wasn't saved with a newer version of ArcGIS than the one installed locally. The error number from ArcObjects is: '-2147220893'. The error message from ArcObjects is: {}
A fatal error has occurred. Check the logfile above for details"
We have recently just started receiving the error on all workbenches that are reading feature classes from a .fgdb. The error is inconsistent between what database it happens on and when (i.e. re-running workbench multiple times in a row, it may read a few times without issue). We have alot of automated processes that should run in the background that are now failing.
We are using FME 2018.1 via ArcGIS Pro Data Interoperability and have recently had a company wide roll out of windows 10 laptops.
I believe the issue is somehow related to the shared drive the data is stored on. As copying data to desktop or another server completely gets rid of the issue (but unfortunately this is not a workable solution). Our IT department is investigating, but they are not familiar and do not support GIS formats or FME....
If anyone has any idea or things I could point IT towards that would be great. Thanks.
Forum|alt.badge.img+39
  • October 10, 2019
I've seen issues where if the filepath to the gdb is too long, FME cannot open the gdb correctly
bruceharold
Forum|alt.badge.img+17
  • October 10, 2019
Network Attached Storage technologies may cause issues, please work with Esri support.
sam_tw
  • October 11, 2019
Interesting! What would be considered too long? Currently the gdb that fails most often is 43 characters long / 6 folders (which I didn't think was particularly long), moving it up a few folders has definitely stopped that error occurring today in my test workbench.
  • October 11, 2019
In our case, it wasn't just the length of the path to the gdb but the length of the featureclass names as well, but this was in excess of 260 characters. (and i think the 260 characters is not a limitation in windows10 anyway)
philippeb
Forum|alt.badge.img+20
  • October 11, 2019
Are you using UNC path or mapped drive ? If it's UNC, that can add a few characters to you path.
Example :
We used to have S:\\project
Now we have to use \\\\city.newyork.gov.usa\\services\\geographic\\project
I'm not the one who approved this change.
sam_tw
  • October 17, 2019
Example :
We are using mapped drives for most of our data. Reducing the file path has definitely helped the issue. But must be the fact that its on network drive as well? As file paths on my desktop are considerably longer and I have never had an issue with those.
dallalana91
Hello there...
I'd find this article and works for me.
https://community.esri.com/t5/arcobjects-sdk-questions/error-workspace-or-data-source-is-read-only-from/td-p/505388
READ-ONLY at GDB folder
Cheers!!
Demetrius Dallalana
