Fgdb Annotations to dgn - callouts
  • November 29, 2012
  • 22 views
owen
Hello,
I have annotations stored in a file geodatabase, and can convert the text into dgn labels.
Is there a way of translating the geomerty of annotation callout boxes into lines/polygons? They do not come through automatically...
Owen
fmelizard
Forum|alt.badge.img+18
  • November 29, 2012
If by 'callout boxes' you mean the bounding box of the text, then yes just use the boundingboxreplacer on the text to get the polygons.
owen
  • November 30, 2012
Thanks Itay. Yes I thought you could do it that way - what I need to do though is bring through the geomerty of the callout.
For example if you place an annotation with a callout box, and move the text, you get a speech bubble type leader line to where it was originally placed.
Is there a way of extracting that information and creating the polygon?
fmelizard
  • November 30, 2012
Hi Owen,
I am not sure I understand you, but if you know the location of the object to which the annotation belong, you can try and add a point (2DPointAdder), for example the UR point of the object boundingbox, to the annotation boundingbox polygon.
