Fetching a zipped CSV file from an ftp site
  • May 16, 2013 6:24 AM UTC
  • 73 views
jan
How can I read a zipped CSV file from a FTP site, extract it and save it. Nothing I have tried seems to work. Has anyone done it successfully? Would need to do it on the both FME server and desktop. I would be thankful for any input.
  • May 16, 2013 7:31 AM UTC
Hi Jan,
this way works for reading a zipped shape file from an ftp server:
Have you tried the same thing for your csv file?
Should be the same for both FME Desktop and Server.
David
  • May 16, 2013 2:04 PM UTC
If you mean read the CSV with FME, what David says is valid for FME 2013, if not I think you'd need some Python and David is probably the right guy here too! ;-)
Does the ftp have open access or does it need user/password to logon? If so I think you'll have to put the credentials in the ftp url.
jan
  • May 16, 2013 7:09 PM UTC
Thanks for the hints. Yes I have FME 2013. Can it be this easy? I'll try it out.
