FeaureWriter FileCopy Fails
  • August 14, 2018
  • 56 views
dmerrick
I have a workspace with an Reader (SDE Connection) writing to multiple different zipped folders before a FileCopy Writer inserts a common disclaimer into each zipped folder. I want to use the FileCopy FeatureWriter due to the output port would then allow me to connect to a S3Uploader transformer and simplify my workspace down from 2 to 1.
I however receive a error of:
Cannot have multiple factories with the same name. Multiple factories were assigned the name 'filecopy_FeatureWriter-FileCopy_d4291b7d_cbed_4650_990f_3e25feda4a160'
Am I missing some parameter setting or is there some workaround using the FileCopy Reader that allows processing after the disclaimer insertion?
Best answer by dmerrick
@XiaomengAtSafe
I downloaded and installed the latest build and the problem is fixed. Thanks!
xiaomengatsafe
Forum|alt.badge.img+11
Hi @dmerrick, can you tell us what version of FME are you using?
dmerrick
  • August 14, 2018
Hi @XiaomengAtSafe, FME(R) 2018.0.0.0 (20180222 - Build 18274 - WIN64)
Thanks
xiaomengatsafe
Thanks
The error you reported is very similar to an issue we've recently fixed. Would you be able to download the latest FME and see if it solves the problem?
dmerrick
  • August 23, 2018
@XiaomengAtSafe
