FeatureReader vs Reader : Esri ArcGIS Server Feature Services
  • Nov 3, 2020 4:12 PM UTC
  • 129 views
dms2
Forum|alt.badge.img+11
I can't connect to a specific ArcGIS Server feature service using a FeatureReader.
I get the service layers listed as output ports but when I execute the translation it throws this error:
ArcGIS Feature Service Reader: Encountered an unexpected error. The error code from the server was '400' and the message was: 'Failed to execute query.'. Details: ''
Using a Reader instead all service layers are read without problem.
I don't understand why the Reader connection works different than the transformer. Any idea?
Generally I would stick to the Reader connection and forget about this weird thing but I prefer using a FeatureReader here because I need to catch any error and work further with it in the translation.
davtorgh
Forum|alt.badge.img+12
  • Nov 3, 2020 6:55 PM UTC
Hi dms2,
based on your description seems the FeatureReader tries to execute a "bad" query against the ArcGIS Server feature service. You may check possible where clause or spatial filter setup in the FeatureReader and, eventually, have a look at this article.
Hope that helps!
dms2
  • Nov 9, 2020 2:22 PM UTC
Hi dms2,
Hope that helps!
I'm not using a where clause or a spatial filter so I don't think that's the problem. Maybe it is the "behind the scenes" query the FeaureREader does to read the data.
I read that article before asking here. It shows a workaround when it is the Reader connection that fails and that's working for me. A pity.
